Please fill out the "Efficiency Curve Temperature Evaluation Variable". As you can see in ForwardTranslateBoilerHotWater.cpp#L106:L114, the curve is translated only if you fill it out.
Note that I don't think that makes much sense though, since in the case of a UniVariateCurve (such as a Cubic one), it's only a function of PLR so the "Efficiency Curve Temperature Evaluation Variable" has zero impact.
