The link you pointed to demonstrates arguments in the OSW Structure section. Also looking in that section see how the Weather file is defined. After addressing the weather file, if the CLI fails, please update the post if there is any feedback on from the CLI on what happened.
You can use "measure_paths" and "file_paths" as shown here. This example is a bit unique in that it points to directories that sit above the OSW file. Typically "measures" , "weather", and "seeds" will sit next to the OSW. I think when in those positions, paths may not have to be defined.
