Appendix G of the ApHVAC user guide covers two methods for modeling hydronic radiant heating and cooling systems that you could adapt to ER. One method uses radiant panels. The other is a bit more complicated, but is probably the most appropriate for the effects you are trying to capture. It requires creating a slab zone to embed the heating source in.
