The minimal amount of weather data is not clearly listed. You will find clues in this section of the Auxiliary Programs Document. This table indicates what variables are used by EnergyPlus.
The more original data you have, the better, but the weather processor can create some data based on other available data (e.g. solar), or EnergyPlus will simply not take into account some data if it's missing (e.g. rain and snow). As you read further down this documentation, there are discussions of what the weather processor will do with alternate or missing data. For example, EnergyPlus reads dewpoint and RH (why both? not sure) but you could provide humidity ratio or wet-bulb to the weather processor and it will convert to DP and RH.
I will make an attempt here to make a list of what I think is the minimal set, but I can't say that I have actually tried this.
