The warning from rpict is just a warning. It's due to your choice of the "-ro" option to specify the output file, which means you want to continue the rendering of a picture that was partially completed by an aborted rpict run. If the file "P40_1230.pic" doesn't exist before you run the command, it warns you about that. Normally, you would use the "-o" option if you are creating a new image.
