Take a look at the Remove Orphan Objects and Unused Resources measure on BCL for an example.
OpenStudio::Model::Curve objects are a child of OpenStudio::Model::ResourceObject [link to documentation], which has a directUseCount method.
So your code could look as simple as:
unused_flag_counter = 0
model.getCurves.sort.each do |resource|
if resource.directUseCount == 0
unused_flag_counter += 1
resource.remove
end
end
@david-goldwasser or I can probably add curves to the Remove Orphan Objects and Unused Resources BCL measure.
resource.remove
end
end
@david-goldwasser or I can probably add I've added curves to the Remove Orphan Objects and Unused Resources measure. The updated version should be on BCL measure.in the next week or so, or you can grab it from GitHub here.
resource.remove
end
end
I've added curves to the Remove Orphan Objects and Unused Resources measure. The updated version should be on BCL in the next week or so, or you can grab it from GitHub here.
| 4 | No.4 Revision |
|curve|
if resource.directUseCount curve.directUseCount == 0
resource.remove
model.removeObject(curve.handle)
end
end
| 5 | No.5 Revision |
model.getCurves.sort.each do |curve|
if curve.directUseCount == 0
end
end
EDIT: use model.removeObject instead of curve.remove because of this issue. Thanks to @Eric Ringold for the workaround.
| 6 | No.6 Revision |
end
end
