I've used the following for calibration in OpenStudio.
@julien marrec's Useful-Excel-Macros-for-Energy-Modeling, which I used to export a JSON file for electricity and gas from an Excel table.
json_validation fork where I made some changes so that the exported files produced valid JSON files.NREL's AddMonthlyUtilityData measure, which is currently hosted in a private repository. Contact the developers if you'd like a copy (I think @brianlball or @davidgoldwasser wrote it).
json_validation fork where I made some changes so that NREL's AddMonthlyUtilityData measure, which is currently hosted in a private repository. Contact the developers if you'd like a copy (I think @brianlball or @davidgoldwasser wrote it).
json_validation NREL's AddMonthlyUtilityData measure, which is currently hosted in a private repository. Contact the developers if you'd like a copy (I think @brianlball or @davidgoldwasser wrote it).
| 4 | No.4 Revision |
json_validation branch where I made some changes so that it produced valid JSON files.NREL's AddMonthlyUtilityData measure, which is currently hosted in a private repository. Contact the developers if you'd like a copy (I think @brianlball or @davidgoldwasser @david goldwasser wrote it).
| 5 | No.5 Revision |
json_validation branch where I made some changes so that it NREL's AddMonthlyUtilityData measure, which is currently hosted in a private repository. Contact the developers if you'd like a copy (I think @brianlball or @david goldwasser wrote it).
