click to hide/show revision 1
initial version
answered 6 years ago
Avi's avatar
Without looking at your model I can recommend on checking the following:
  1. Make sure you set the right infiltration.
  2. Make sure that you set the right amount of outside Air.
  3. Use the right ground model. This one is a big gotcha since for small and medium building the ground coupling model can change results dramatically. You can read about it in my chained answer to that question.
