@Avi Thank you for your kind answer. I want to ask more about tweak the performance thing. Is that mean that I can model the refrigerant loop by modeling a water loop instead and make some revision on performance coefficient inside EnergyPlus idf file then get a result looks like a result of a refrigerant loop? I am asking because I am not sure that I understood right.
