I don't see an actual question in your post, so I can only assume you'd like some kind of summary to be available in the HTML output. You should look at Output:Table:XXX objects, namely Output:Table:Annual Output:Table:Monthly.
You could set up something like the following:
Output:Table:Monthly,
Dehumidifier DX Report, !- Name
, !- Digits After Decimal
Zone Dehumidifier Sensible Heating Energy, !- Variable or Meter 1 Name
SumOrAverage, !- Aggregation Type for Variable or Meter 1
Zone Dehumidifier Sensible Heating Rate, !- Variable or Meter 2 Name
Maximum, !- Aggregation Type for Variable or Meter 2
Zone Dehumidifier Sensible Heating Rate, !- Variable or Meter 3 Name
HoursNonZero, !- Aggregation Type for Variable or Meter 3
Zone Dehumidifier Electric Energy, !- Variable or Meter 4 Name
SumOrAverage, !- Aggregation Type for Variable or Meter 4
Zone Dehumidifier Electric Power, !- Variable or Meter 5 Name
Maximum, !- Aggregation Type for Variable or Meter 5
Zone Dehumidifier Runtime Fraction, !- Variable or Meter 6 Name
SumOrAverage, !- Aggregation Type for Variable or Meter 6
Zone Dehumidifier Part Load Ratio, !- Variable or Meter 7 Name
SumOrAverage; !- Aggregation Type for Variable or Meter 7
This will give you a table like this one (click to see it full size) for each zone where you have a Dehumidifier:
