Hi Katsuya,
You can check the following image for inheritance model. I hope it helps.
https://nrel.github.io/OpenStudio-user-documentation/img/model/openstudio_inheritance.jpg
Hi Katsuya,
So, Kindly check or remove the construction assignment at space or space type. If we go by the inheritance model, it should work.
Regards
