I think the standard PAT results described here should be what you are looking for. If you want to know what the savings is from a specific measure then you need to run a design alternative with only that measure applied. This avoids any interactions with other measures.
We do have an analysis period cash flow reporting measure that reports cash flow over the analysis period. It just graphs data that comes out of EnergyPlus
