To my best knowledge that is not possible in OS or in E+.
Maybe you can use SolarCollector:FlatPlate:PhotovoltaicThermal (PVT) which you can connect to a Water to Water Heat Pump at the source side. You will probably have to tweak the performance in order to reach the predicted DX performance.
