You are correct that utility tariffs are not yet part of OpenStudio. This EnergyPlus measure loads tariffs in IDF format and adds them to your IDF before simulation, this is currently the best way to investigate utility tariffs in OpenStudio. You can follow this feature request for updates on when a full utility rate GUI might be added to OpenStudio.
