Hello @Phylroy Lopez nice to meet you :)
The basic approach in PAT, is to add multiple EPW files to the folder below "Default Weather File" on the measure options tab as described here.
On the design alternatives tab, for each design alternative you can choose a unique seed model and weather file as described here.
I often do as you suggest and add a measure to change the weather file, as this allows me to not only change the epw, but also the design days, climate zone, and water main temperatures. Change Building Location measure on BCL expects the user to provide the weather file. Currently it has a path and file name argument. Later today I can post an updated version that uses newer methods to find files. It has an argument just for the file name. You can manually set climate zone or that can be inferred from the stat file.
The updated version uses a 2x only method runner.workflow.findFile(weather_file_name) that looks in a number of locations described in the OSW file. I copy the epw, ddy, and stat file of the same name to the "weather" directory for the PAT project.
There is another measure I may post that takes a zipcode for the user argument. It then downloads the closest site component from BCL and adds it two your project.
If you go to algorithmic mode you can add "Additional Analysis Files" as described here. This will copy files external to you project into the analysis when it is sent to the server to run. It is a nice way to have shared resources across PAT projects. As a note, while you have to go to algorithmic mode to set this up; once you switch back to manual analysis mode measures will still have access to those files.
# get variables
weather_file_name = runner.getStringArgumentValue('weather_file_name', user_arguments)
climate_zone = runner.getStringArgumentValue('climate_zone', user_arguments)
# find weather file
osw_file = runner.workflow.findFile(weather_file_name)
if osw_file.is_initialized
weather_file = osw_file.get.to_s
else
runner.registerError("Did not find #{weather_file_name} in paths described in OSW file.")
return false
end
# Parse the EPW
epw_file = OpenStudio::Weather::Epw.load(weather_file)
The updated version uses a 2x only method runner.workflow.findFile(weather_file_name) that looks in a number of locations described in the OSW file. I copy the epw, ddy, and stat file of the same name to the "weather" directory for the PAT project. The new method in context is shown below.
# get variables
# find weather file
else
return false
end
# Parse the EPW
| 4 | No.4 Revision |
I often do as you suggest and add a measure to the workflow to change the weather file, as this allows me to not only change the epw, but also the design days, climate zone, and water main temperatures. Change Building Location measure on BCL expects the user to provide the weather file. Currently it has a path and file name argument. Later today I can post an updated version that uses newer methods to find files. It has an argument just for the file name. without a path. You can manually set climate zone or that can be inferred from the stat file.
The recently updated version uses a 2x only method runner.workflow.findFile(weather_file_name) that looks in a number of locations described in the OSW file. I You should manualy copy the epw, ddy, and stat file of the same name to the "weather" directory for the PAT project. The new method in context is shown below.
# get variables
# find weather file
else
return false
end
# Parse the EPW
There is another A new measure I may post that on BCL named Get Site from Building Component Library takes a zipcode for the user argument. It then downloads the closest site component from BCL and adds it two your project.
| 5 | No.5 Revision |
I often do as you suggest and add a measure to the workflow to change the weather file, as this allows me to not only change the epw, but also the design days, climate zone, and water main temperatures. Change Building Location measure on BCL expects the user to provide the weather file name without a path. You can manually set climate zone or that can be inferred from the stat file. The recently updated version uses a 2x only method runner.workflow.findFile(weather_file_name) that looks in a number of locations described in the OSW file. You should manualy copy the epw, ddy, and stat file of the same name to the "weather" directory for the PAT project. The new method in context is shown below.
# get variables
# find weather file
else
return false
end
# Parse the EPW
A I plan to add a new measure on BCL named Get Site from Building Component Library that takes a zipcode for the user argument. It then downloads the closest site component from BCL and adds it two your project.
| 6 | No.6 Revision |
# get variables
# find weather file
else
return false
end
# Parse the EPW
I plan to add a new The Get Site from Building Component Library measure on BCL that takes a zipcode for the user argument. It then downloads the closest site component from BCL and adds it two your project.
