From the error message, it looks like you've got an uninitialized EMS variable. You'll need to provide an initialization. That was previously allowed, but was changed for version 8.6. Here's the issue that was raised:
https://github.com/NREL/EnergyPlus/issues/4943
And the pull request that made the change is here:
https://github.com/NREL/EnergyPlus/pull/5660
That link is failing to load for me right now (the dreaded GitHub angry unicorn), but the change is listed in the changelog here. It's listed under "Defects Repaired".
From the error message, it looks like you've got an uninitialized EMS variable. You'll need to provide an initialization. That was Uninitialized variables were previously allowed, but was that changed for version 8.6. Here's the issue that was raised:
From the error message, it looks like you've got an uninitialized EMS variable. You'll need to provide an initialization. Uninitialized variables were previously allowed, but that was that changed for version 8.6. Here's the issue that was raised:
