When you are on th design alternative tab select all the measures you want to string together and choose "Make one from selected measures".
Look at this video for a demonstration.
Page 8 of this pdf gives a quick overview as well.
When you are on th the design alternative tab select all the measures you want to string together and choose "Make one from selected measures".
