You probably need a Humidity SetpointManager:
SetpointManager:MultiZone:Humidity:Minimum SetpointManager:MultiZone:MinimumHumidity:Average
This is related to a small bug #1465 where the humidity SPM icon doesn't show up on the node when added. However, if you click on the node you should be able to edit the SPM.
This is related to a small bug #1465bug where the humidity SPM icon doesn't show up on the node when added. However, if you click on the node you should be able to edit the SPM.
