I have the same problem, but I can not find the line that E + warns, even opening the file in SU. Everything looks ok. Anyone with the same problem?
The warning: * Warning * CalculateZoneVolume: The Zone="94" is not fully enclosed. To be fully enclosed, each edge of a surface must also be an edge on one other surface. * ~~~ * The zone volume was calculated using the floor area times ceiling height method where the floor and ceiling are the same except for the z-coordinates. * ~~~ * The surface "94_CEILING_1_0_0" has an edge that is either not an edge on another surface or is an edge on three or more surfaces: * ~~~ * Vertex start { 0.2121, -0.4419, 3.3000} * ~~~ * Vertex end { -1.3081, 1.0783, 3.3000} * ~~~ * The surface "94_CEILING_1_2_1" has an edge that is either not an edge on another surface or is an edge on three or more surfaces: * ~~~ * Vertex start { 2.1567, -2.3865, 3.3000} * ~~~ * Vertex end { 0.2121, -0.4419, 3.3000}
The surface IDF:
BuildingSurface:Detailed, 94_Ceiling_1_0_0, !- Name Ceiling, !- Surface Type 3, !- Construction Name 94, !- Zone Name Surface, !- Outside Boundary Condition 228_Floor_0_0_10061, !- Outside Boundary Condition Object NoSun, !- Sun Exposure NoWind, !- Wind Exposure 0, !- View Factor to Ground , !- Number of Vertices 2.6625, !- Vertex 1 X-coordinate {m} -1.6875, !- Vertex 1 Y-coordinate {m} 3.3, !- Vertex 1 Z-coordinate {m} 2.6625, !- Vertex 2 X-coordinate {m} 0.4625, !- Vertex 2 Y-coordinate {m} 3.3, !- Vertex 2 Z-coordinate {m} 0.1625, !- Vertex 3 X-coordinate {m} 0.4625, !- Vertex 3 Y-coordinate {m} 3.3, !- Vertex 3 Z-coordinate {m} 0.1625, !- Vertex 4 X-coordinate {m} -1.6875, !- Vertex 4 Y-coordinate {m} 3.3; !- Vertex 4 Z-coordinate {m}
BuildingSurface:Detailed, 94_Ceiling_1_2_1, !- Name Ceiling, !- Surface Type 3, !- Construction Name 94, !- Zone Name Surface, !- Outside Boundary Condition 265_Floor_0_0_10042, !- Outside Boundary Condition Object NoSun, !- Sun Exposure NoWind, !- Wind Exposure 0, !- View Factor to Ground , !- Number of Vertices 0.3375, !- Vertex 1 X-coordinate {m} 0.4625, !- Vertex 1 Y-coordinate {m} 3.3, !- Vertex 1 Z-coordinate {m} 0.3375, !- Vertex 2 X-coordinate {m} 3.2125, !- Vertex 2 Y-coordinate {m} 3.3, !- Vertex 2 Z-coordinate {m} 0.1625, !- Vertex 3 X-coordinate {m} 3.2125, !- Vertex 3 Y-coordinate {m} 3.3, !- Vertex 3 Z-coordinate {m} 0.1625, !- Vertex 4 X-coordinate {m} 0.4625, !- Vertex 4 Y-coordinate {m} 3.3; !- Vertex 4 Z-coordinate {m}
