In the HVAC System Panel, you have to replace the object: AirTerminal:SingleDuct:Uncontrolled by AirTerminal:SingleDuct:ConstantVolume:Reheat, just remove the default AirTerminal, and look for the new AirTerminal in the Library Tab. After you have dragged it, you'll see in the Edit tab the "OS:Coil:Heating:Gas" where you can modify your coil.
