Matt, that is a good catch. The logic in the existing measures that change single and two speed dx COP's loops through air loops, and then supply components. You want to loop through zone equipment instead. The code below should do what you want. It is specifically looking for PTAC with single speed DX, but you could expand it to look for other types of objects.
# loop through zone equipment
model.getZoneHVACComponents.each do |component|
# see if it is a PTAC
if component.to_ZoneHVACPackagedTerminalAirConditioner.is_initialized
runner.registerInfo("#{component.name} is a PTAC")
ptac = component.to_ZoneHVACPackagedTerminalAirConditioner.get
# get the cooling coil
coil_cooling = ptac.coolingCoil
# see if it is single speed dx
if coil_cooling.to_CoilCoolingDXSingleSpeed.is_initialized
single_speed_dx = coil_cooling.to_CoilCoolingDXSingleSpeed.get
runner.registerInfo("The intial COP is #{single_speed_dx.ratedCOP}")
# set cop
target_cop = 1.5 * single_speed_dx.ratedCOP.get # need the get because ratedCOP returns an optional, should check if it exists before doing a get
optionalDoubleCOP = OpenStudio::OptionalDouble.new(target_cop) # not many objects need this step, this is an odd one
single_speed_dx.setRatedCOP(optionalDoubleCOP)
runner.registerInfo("The adjusted COP is #{single_speed_dx.ratedCOP}")
else
# could add in elsif to look for other types of cooling coils
end
else
# could add in elsif to look for other kinds of zone equipment
end
end
Here is the documentation on ZoneHVACPackagedTerminalAirConditioner
And here is the documentation on CoilCoolingDXSingleSpeed
