We have limited data to work with, but given the eplusout.err snippet you shared, I think your LoadProfile:Plantobject is generating demand far in excess of what your PlantLoop supply side (chillers and pump) can actually provide.
The root cause can be one (or a combination) of several factors:
Anyways, I'd start investigating on that front, it shouldn't be too long until you find a severe mismatch (your plant temperatures are getting really hot and you have a TON of unmet demand on your plant loop).
