SketchUp remains free for non-commercial use, to download this version you simply need to choose “Personal Projects” or "Educational Use" under what you plan to use SketchUp for when you download it. You can also download the Make version of SketchUp directly from this page. However, if you download the professional version, the free trial will expire and prompt you to purchase the product. The OpenStudio team plans to support alternative geometry workflows that do not require SketchUp (hopefully in 2016). The options to create geometry in OpenStudio currently available are:
Options underway (scheduled for 2015 release):
The OpenStudio team would love to collaborate with or support developers looking to build standalone geometry tools or plug-ins for other CAD software that write to either OpenStudio directly or indirectly via gbXML.
We have just finished a reporting measure that will render the 3D OpenStudio model for inspection. This measure will work in OpenStudio 1.6.3 or higher. This measure is at https://bcl.nrel.gov/node/82771.
We have just finished a reporting measure that will render the 3D OpenStudio model for inspection. This measure will work in OpenStudio 1.6.3 or higher. NREL). This measure is at https://bcl.nrel.gov/node/82771.
| 4 | No.4 Revision |
| 5 | No.5 Revision |
Additionally we would like to build a merge tool to allow users to merge geometry changes made by another tool with their current working OpenStudio model.
| 6 | No.6 Revision |
| 7 | No.7 Revision |
| 8 | No.8 Revision |
SketchUp remains free for non-commercial use, to download this version you simply need to choose “Personal Projects” or "Educational Use" under what you plan to use SketchUp for when you download it. You can also download the Make version of SketchUp directly from this page. However, if you download the professional version, the free trial will expire and prompt you to purchase the product. The OpenStudio team plans to support alternative geometry workflows that do not require SketchUp (hopefully in beyond 2016). The options to create geometry in OpenStudio currently available are:
| 9 | No.9 Revision |
SketchUp remains free for non-commercial use, to download this version you simply need to choose “Personal Projects” or "Educational Use" under what you plan to use SketchUp for when you download it. You can also download the Make version of SketchUp directly from this page. However, if you download the professional version, the free trial will expire and prompt you to purchase the product. The OpenStudio team plans to support alternative geometry workflows that do not require SketchUp (beyond 2016). The options to create geometry in OpenStudio currently available are:
Options underway (scheduled for 2015 release):Other options:
