ASHP: I believe the BEopt options are meant to be generic. However, the BEopt variable speed ASHP may be based on something similar to the Nordyne iQ Drive or Carrier Infinity with Greenspeed.
MSHP: Yes, the capacity degradation is linearly extrapolated below the capacity retention temperature. COP is not involved in that extrapolation. My understanding is that most "cold climate" MSHP units do not actually have a compressor lock out temperature and people have observed them continuing to output heat even below the manufacturer specified minimum temperatures (typically -13 F or -15 F).
ASHP: I believe the BEopt options are meant to be generic. However, the BEopt variable speed ASHP may be is somewhat based on something similar to the Nordyne iQ Drive or Carrier Infinity with Greenspeed.Drive.
MSHP: Yes, the capacity degradation is linearly extrapolated below the capacity retention temperature. COP is not involved in that extrapolation. My understanding is that most "cold climate" MSHP units do not actually have a compressor lock out temperature and people have observed them continuing to output heat even below the manufacturer specified minimum temperatures (typically -13 F or -15 F). F).
