You found a problem in the API and I opened a GitHub issue here. You can find more details on why it's not working in said issue.
The bottom line is that this object is indeed missing tertiary node implementation and therefore cannot be connected to the generator nodes.
So you have two options:
ChillerAbsorptionIndirect object. I strongly suggest you do that. The I/O ref is quite explicit here: ChillerAbsorptionIndirect is exactly the same as ChillerAbsorption but better, and ChillerAbsorption may get deprecated as a result... And the good thing is that ChillerAbsorptionIndirect does allow connecting the generator nodes. | 2 | No.2 Revision |
