Do you have OpenStudio installed and enabled?
Once you have it, you still can't directly open .skp files (and have OpenStudio understand the geometry), but what you can do is create a new OpenStudio model and then incrementally copy the geometry from the .skp file into that model one space or zone at a time. Here is an older post that describes this process.
