I recently updated this measure. Changelog on Github here.
The measure looks through all your fenestration objects, selects ones that match the construction you specify, and then makes an add wind stack object for each one. The issue you are facing is likely that there aren't any windows in your model with the construction you selected in the measure arguments. Make sure that you aren't overriding your window constructions elsewhere in your model; there are many places to specify constructions in OpenStudio. If you go to the spaces -> subsurfaces tab, you can see which construction set is being applied to your windows.
