Monodraught helped me get to the bottom of this. Should anyone have a similar problem in the future see below:
The thermal template assigned to the windcatchers and associated ducts should be "Monodraught WINDCATCHER/Duct" for some reason this was not being pulled in when adding the windcatcher components. Having manually loaded the template and applied it to the relevant spaces the model runs fine.
