There is currently a difference between the way the Results Viewer interprets results from DesignBuilder and OS. This is related to sizing information from OS being included at the beginning of the results, showing the sort of display you have encountered. This does not affect DesignBuilder results. We anticipate this being fixed for OS outputs later this year but in the meantime, to avoid this occurring, the workaround is to turn off the OS SimulationControl object with Run Simulation for Sizing Periods=No. The sizing results will then not be added to the ESO file before the standard EnergyPlus simulation outputs.
