As per comments.
Add a thermal zone for each room. Name each space and thermal zone. Add thermostat for each thermal zone. Ensure each space is set to ideal air loads. Set schedules for thermostats. There are a number of good thermostat measures in the building component library. I would also recommend that you search on You Tube for openstudio tutorials and look on the openstudio website for the quick tutorials. As stated previously, use xeso viewer, which is free to download and the best viewer for the results in openstudio
