If you search the DesignBuilder Help file for "simulation results" you will find information on all the results that are displayed in the DesignBuilder interface. These are only the most commonly used useful results. If you need more than that the DesignBuilder Results Viewer can display any EnergyPlus output. If you run a simulation and take a look at the RDD file (all of the input and output files are stored in the File > Folders > EnergyPlus folder) then you can see what outputs are relevant to your particular model. If you aren't sure which output represents what then the EnergyPlus Input Output Reference document explains them.
