The issue is the use of the COP where the expression requires EER. Using the COP of 3.16 you reference, that is an EER of 10.78. NOTE: my 90.1-2007 has slightly different EER ratings than what you are referencing. It has EER= 10.6 which is a COP of 3.1067. Minor, but may impact answer.
COP_nfcooling = 7.84e-8(10.78)*(136480)+0.338(10.78) = 0.115 + 3.644 = 3.759 where "nf" = no fan I believe.
Unsure why you bumped the cooling capacity from 39 kW to 40kW. any reason?
The expressions in the post you linked from @Anna Osborne Brannon should work for the heating COP as well.
![]() | 2 | No.2 Revision |
The expressions in the post you linked from @Anna Osborne Brannon @Anna_Osborne_Brannon should work for the heating COP as well.
![]() | 3 | No.3 Revision |
The expressions in the post you linked from @Anna_Osborne_Brannon @(Anna Osborne Brannon) should work for the heating COP as well.
![]() | 4 | No.4 Revision |
The expressions in the post you linked from @(Anna Osborne Brannon) should work for the heating COP as well.
![]() | 5 | No.5 Revision |
The expressions in the post you linked from should work for the heating COP as well.
![]() | 6 | No.6 Revision |
The expressions in the post you linked from @"Anna Osborne Brannon" should work for the heating COP as well.
![]() | 7 | No.7 Revision |
The issue is the use of the COP where the expression requires EER. Using the COP of 3.16 you reference, that is an EER of 10.78. NOTE: my IP 90.1-2007 has slightly different EER ratings than what you are referencing. It has EER= 10.6 which is a COP of 3.1067. Minor, but may impact answer.
