You didn't give all parameters so we could actually recreate your numbers, but it's a simple explanation so you'll have no trouble doing it yourself.
You can just read up on this in the Engineering Reference. For a Simple Model, the power output is calculated as [1] :
$$P = A_{surf} \cdot f_{active} \cdot G_{T} \cdot \eta_{cell} \cdot \eta_{inverter}$$
Where:
PhotovoltaicPerformance:Simple[1] Source: Engineering Reference: Photovoltaic Arrays: Mathematical description
Where:
