The outputs you are after are referenced in the EnergyPlus documentation guide "InputOutputReference", page 218. You should be able to find this document folder from wherever EnergyPlus has been installed on your PC.
In your EnergyPlus IDF editor you will need to "call" for these Green Roof output variables, using the Output:Variable object.
