I do it like this: If you look at idf of your model after analysis, in output:variables section you can add a new object and see a drop-down list of available variables. It is huge usually, so you should check it carefully and better to look at E+ input-output documentation first. Then you can copy the variable name and paste in your model either by using respective measurement or going to SU model and add a new variable in OS inspector.
BTW it is a good topic as soon as OS lacks variables management instruments. Would be great to see them systematized and have the same drop-down list for adding new ones to not check E+ documentation every time.
