It should be model.getCoilHeatingWaterToAirHeatPumpEquationFits (note the s on the end). This paradigm is true for all OpenStudio objects where, for object Foo, you specify model.getFoos.
It should be model.getCoilHeatingWaterToAirHeatPumpEquationFits (note the s "s" on the end). This paradigm is true for all OpenStudio objects where, for object Foo, you specify model.getFoos.
