To my best knowledge one hour resolution is the usual. You might want to read in the Auxiliary Programs Manual about the weather converter
When you use that site to find epw file you will end up with a file containing 8768 lines of them 8 are header lines and the rest is weather data. This is 365*24=8760 data points.
I believe you are good to go with hourly data.
When you use that site to find epw file you will end up with a file containing 8768 lines of them 8 are header lines and the rest is weather data. This That is 365*24=8760 data points.
