As I understand , you want to adjust the power of your boiler according to heating demand to keep it on all the time and reduce the number of on-off operations? What is the purpose to simulate this? The amount of heating energy will be the same, obviously. It will affect only on primary loop pump consumption (will increase it). As far as I am concerned, there is no native way to model inter-variables dependency in E+ (IES-VE can). You should look at your weather file and manually create a schedule to control the power of your boiler.
