If a large portion of the mechanical power of the impeller would be converted to rotational energy, the the fan would constantly accelerate. In reality what happens, if you feed a fan's motor with constant power, then the fan starts to accelerate, and after a while it rotates with a constant speed. As soon as the fan is at constant speed, the power fed in to increase the rotational energy of the fan is equal to the power, that the fan feeds into the mechanical energy of the air. These two powers (motor-> fan & fan-> air) are in balance, that is why the fan rotates at constant speed, and why all this energy goes to heat.
To me the equation looks correct. The minor things, that you may argue with, may be:
If a large portion of the mechanical power of the impeller would be converted to rotational energy, the the fan would constantly accelerate. In reality what happens, if you feed a fan's motor with constant power, then the fan starts to accelerate, and after a while it rotates with a constant speed. As soon as the fan is at constant speed, the power fed in to increase the rotational energy of the fan is equal to the power, that the fan feeds into the mechanical energy of the air. These two powers (motor-> fan & fan-> air) are in balance, that is why the fan rotates at constant speed, and why all this energy goes to heat. heat (the air stops moving after a while and its energy dissipates to heat).
If a large portion of the mechanical power of the impeller would be converted to rotational energy, the the fan would constantly accelerate. In reality what happens, if you feed a fan's motor with constant power, then the fan starts to accelerate, and after a while it rotates with a constant speed. As soon as the fan is at constant speed, the power fed in to increase the rotational energy of the fan is equal to the power, that the fan feeds into the mechanical kinetic energy of the air. These two powers (motor-> fan & fan-> air) are in balance, that is why the fan rotates at constant speed, and why all this energy goes to heat (the air stops moving after a while and its energy dissipates to heat).
