If surface 89 and surface 116 represent floor surfaces of adjacent spaces then they should not reference each other as outside boundary objects. What is the origin of the geometry and surface matching of the model?
If these two surfaces represented the shared wall or shared floor/ceiling surface between the spaces then the constructions used for each surface need to be mirrors of each other.
