You can request output variable at various timesteps, including hourly, using the Output Variables tab in the OpenStudio application. This tab doesn't give an comprehensive list, if you want to add any other variable from the .rdd file you can use the Add Output Variable measure on BCL.
What type of data are you looking for. the .mdd file can be used to find meters that you can get timeseries data for using the Add Meter measure on BCL.
