First, double-check that you are plotting output variables correctly: Is Zn001:FLR001 really the floor surface for WEST ZONE?
If so, then mean radiant temperature (MRT) can be calculated in different ways. It seems that the output variable in your image is from a Zone object's calculations for MRT. This approach uses a surface area × emissivity weighted average of the zone inside surface temperatures. Another option would be to set Mean Radiant Temperature Calculation Type and Surface Name/Angle Factor List Name input fields in the People object for WEST ZONE in order to account for specific placement of occupants within the zone. Then, you want to add the Zone Thermal Comfort Mean Radiant Temperature output variable to the IDF and run a new simulation to generate that new MRT output variable.
Some things that might be causing this large temperature difference between radiant floor inside face temperature and zone air temperature:
