1 | initial version |
I would start by reading the input/ouput manual for solar collectors (here). It will give you an overview of what is available and how to go about implementing what you need in your model. If you are looking for examples, I would also suggest that you take a look at the example files that comes with EnergyPlus. They are located in the ExampleFiles folder of the EnergyPlus installation directory.
