As far as I know Eppy doesn't include any results viewing capability. Check the run folder, you should have the HTML, SQL (if requested), etc. You can query these using python but you'll need to write your own code.
You can also look at the HTML in your browser, and you could view the SQL file in a third party tool such as DView
![]() | 2 | No.2 Revision |
You can also look at the HTML in your browser, and you could view the SQL file in a third party tool such as DViewDView, which comes with OpenStudio or in standalone version here
