To project the PV (or whatever) surface along a base surface nromal regardless of the surface's tilt/orientation (which is How It Should Be Done), do something like this:
# get the base surface normal (vector)
vec = surface.outwardNormal
vec.setLength(0.0254) # PV/shading/whatever surface projection (m)
# get window points and project along window normal
vertices = surface.vertices
transform = OpenStudio::Transformation.new
transform = surface.space.get.transformation if surface.space.is_initialized
# transform to world coords
vertices = transform * vertices
points = []
vertices.each do |f|
if debug_mode
runner.registerInfo("window vertex: #{f}, projected PV vertex: #{f + vec}")
end
pp = f + vec
points << pp
end
points = transform.inverse * points # send back to space coords
# Make the new PV/shading/whatever surface
shading_surface = OpenStudio::Model::ShadingSurface.new(points, model)
points = []
if debug_mode
end
pp = f + vec
points << pp
end
To project the PV (or whatever) surface along a base surface nromal normal regardless of the surface's tilt/orientation (which is How It Should Be Done), do something like this:
points = []
pp = f + vec
points << pp
end
