We have a measure that we use internally for this purpose. I just posted ReportModelChanges to BCL. In our case we often use measures to create the model in which all of the handles/UUID's are different, making a text editor tough to use. @MatthewSteen's suggestion of looking at the out.idf is one good option, but we wanted something to specifically look at OSM's
While this measure doesn't alter your model, it runs as a "Model" vs. "Reporting" measure since it only needs model inputs vs. model outputs. As a result you can use it in with "Apply Measures Now". The resulting info message has a link to an HTML file that looks something like what is shown below. There are three sections.
Below is a screenshot of the third section. Items where there is a difference are highlighted in red.
