You could model the renewables in Modelica with the Buildings library, export the Modelica model as an FMU (JModelica generates FMU by default) and import this FMU into EnergyPlus using its FMU import facility. Conversely, you could export EnergyPlus as an FMU and import it into a Modelica modeling environment.
