Have you tried looking at example files? Also, what objects exactly are you using?
There are several example files that use Coil:WaterHeating:AirToWaterHeatPumpobjects.
You can find the example files in C:\EnergyPlusV8-8-0\ExampleFiles, and the "ExampleFiles-ObjectsLink.html" document in this folder lists the objects used.
