@mapasqual the surface matching script never really worked good enough for me. I found an alternative solution that worked really well. Using Honeybee which is part of the lady bug tools (set of plugins for rhino/ grasshopper I am able to match surfaces easily. I recently built a building with 300+ zones (12 story model) which was easily imported into OS. All surfaces matched 100% correctly with no duplicate names. Best, Fabian
@mapasqual the surface matching script never really worked good enough for me. I found an alternative solution that worked really well. Using Honeybee which is part of the lady bug tools (set of plugins for rhino/ grasshopper ) I am able to match surfaces easily. I recently built a building with 300+ zones (12 story model) which was easily imported into OS. All surfaces matched 100% correctly with no duplicate names.
Best,
Fabian
@mapasqual the surface matching script never really worked good enough for me. I found an alternative solution that worked really well. Using Honeybee which is part of the lady bug tools (set of plugins for rhino/ grasshopper) I am able to match surfaces easily. I recently built a building with 300+ zones (12 story model) which was easily imported into OS. All surfaces matched 100% correctly with no duplicate names.
Best,
Fabiannames.
| 4 | No.4 Revision |
@mapasqual mapasqual the surface matching script never really worked good enough for me. I found an alternative solution that worked really well. Using Honeybee which is part of the lady bug tools (set of plugins for rhino/ grasshopper) I am able to match surfaces easily. I recently built a building with 300+ zones (12 story model) which was easily imported into OS. All surfaces matched 100% correctly with no duplicate names.
| 5 | No.5 Revision |
In my original post I mentioned that honeybee would struggle with large models. That is no longer the case. Honeybee version 063 no longer has this issue.
