1 | initial version |
The performance of a cooling tower is very dependent on outdoor wet-bulb temperature. See equation 17.3 on pg 977 in V8.8 Engineering Reference. However, if there is a set point temperature on the condenser loop, the tower should control to that temperature.
CondenserLoop, Chilled Water Condenser Loop, !- Name Water, !- Fluid Type , !- User Defined Fluid Type Tower Loop Operation, !- Condenser Equipment Operation Scheme Name Condenser Supply Outlet Node, !- Condenser Loop Temperature Setpoint Node Name
2 | No.2 Revision |
CondenserLoop,
3 | No.3 Revision |
The performance of a cooling tower is very dependent on outdoor wet-bulb temperature. See equation 17.3 on pg 977 in V8.8 Engineering Reference. However, if there is a set point temperature on the condenser loop, the tower should control to that temperature. Also read section 17.1.1.4 Calculating the Actual Exiting Water Temperature and Fan Power on pg 980.
CondenserLoop,
